VWC 0 Posted June 15, 2009 Author Report Share Posted June 15, 2009 thats cany impressive im only looking at around 300 with my v9 almost maxed out think i mite go for one of them my comp is alredy 9:1 off a spacer plate so would be rude not to what sort of power would you expect with a 70mm pully?cheer johnmy old v9 with 12psi pully made 337hp so compression and pistons etc will be fine, cooling is always good you want to be blowing cool air in makes so much difference on boost lossnot sure what 70mm will do be interesting though will update once i get the numbers Link to post Share on other sites
bobveedub 0 Posted June 21, 2009 Report Share Posted June 21, 2009 good god that car is amazing! well done, keep up the good work! Link to post Share on other sites
john555 0 Posted July 27, 2009 Report Share Posted July 27, 2009 just been watching your video of your car boosting and its made me so excited to get mine, your car sounds mental i bet its a handfulwhat size pully do you have to make 430bhp im goin to buy a setup with a 70mm pully on it but i dont think my car would take that Link to post Share on other sites
J5KE F 0 Posted July 27, 2009 Report Share Posted July 27, 2009 Love it I ditched my v9 for the same reasons, now rotrex c32 and custom pulley. what are u runnin on the strip? Link to post Share on other sites
VWC 0 Posted July 27, 2009 Author Report Share Posted July 27, 2009 just been watching your video of your car boosting and its made me so excited to get mine' date=' your car sounds mental i bet its a handfulwhat size pully do you have to make 430bhp im goin to buy a setup with a 70mm pully on it but i dont think my car would take that [/quote']mine is a c30-94 with a 80mm pulley boost is 18psimight be going 70mm pulley soon since my bottom build with wossner pistons & h-beam rods :-)started to put it all back together yesterday Link to post Share on other sites
Mark_H 0 Posted July 27, 2009 Report Share Posted July 27, 2009 HI,Sorry ti Hijack the thread....Have you got any pictures of the top cam pulleys with the chain on....I'm trying to work out if I have the cam sensor pick up missing from mine....Is the cam an OBD II car. ? Link to post Share on other sites
craggsy 91 Posted July 27, 2009 Report Share Posted July 27, 2009 So would you be selling the pulley when you upgrade as I might be tempted. I should be ok as im running same charger as you with spacer plate and ARPs.Only if it would be reliable and not blow Link to post Share on other sites
VWC 0 Posted July 28, 2009 Author Report Share Posted July 28, 2009 HI' date='Sorry ti Hijack the thread....Have you got any pictures of the top cam pulleys with the chain on....I'm trying to work out if I have the cam sensor pick up missing from mine....Is the cam an OBD II car. ?[/quote']got this pic if it helps Link to post Share on other sites
VWC 0 Posted July 28, 2009 Author Report Share Posted July 28, 2009 So would you be selling the pulley when you upgrade as I might be tempted. I should be ok as im running same charger as you with spacer plate and ARPs.Only if it would be reliable and not blowYeah will sell it what pulley you running now - what boost you at Link to post Share on other sites
Mark_H 0 Posted July 28, 2009 Report Share Posted July 28, 2009 excellent thanks...Do you know why yours is different to this ? I'm trying to work out if I have a problem with the sensor ring !!!!!!!!http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?302479 Link to post Share on other sites
craggsy 91 Posted July 28, 2009 Report Share Posted July 28, 2009 So would you be selling the pulley when you upgrade as I might be tempted. I should be ok as im running same charger as you with spacer plate and ARPs.Only if it would be reliable and not blowYeah will sell it what pulley you running now - what boost you atnot 100% sure which pulley I have. the guy I bought it from said it was the 6psi pulley, and still dont have boost gauge inplace. Job for Thursday i think Link to post Share on other sites
john555 0 Posted July 28, 2009 Report Share Posted July 28, 2009 your car is amazing mate whats it lke to map can it still be setup on the standard ecu Link to post Share on other sites
VWC 0 Posted July 28, 2009 Author Report Share Posted July 28, 2009 excellent thanks...Do you know why yours is different to this ? I'm trying to work out if I have a problem with the sensor ring !!!!!!!!http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?302479not too sure why its different mine is obd1, might be worth asking stealth about the code, have you tried another cam sensor worth a go to see if the fault comes up Link to post Share on other sites
VWC 0 Posted July 28, 2009 Author Report Share Posted July 28, 2009 your car is amazing mate whats it lke to map can it still be setup on the standard ecuyeah its standard ecu obd1 setupthis has been tuned with bosch 440cc injectors and an enlarged maf housing using tt maf sensor Link to post Share on other sites
VWC 0 Posted August 3, 2009 Author Report Share Posted August 3, 2009 Update…Cars been running on 5 and a bit cylinders despite pulling 430hp on the rollersSo after 14 years and 125k so it was time to get the bottom end rebuilt.Pulled out the bottom end – painted it up then got it rebored to 2897cc.Went for Wossner Forged Pistons with H-Beam Con RodsAt the same time added Cromoly 9lb Flywheel and Helix Clutch as the standard ones were pretty worn from the power.Sorted a few other bits like new Water Pump & Oil Pump plus CrazyDaves Spal Brackets and new Radiator.Spent the last week building it back up and now its up and running – did have a few issues - gear linkage and power steering – but nothing majorRunning 14s on the PLX with no engine faults and idle is spot onNot too concerned with the power right now but its good to know engine can cope with over 400 horses so just got to run it in over the next few weeks then may go for a 70mm pulley. Link to post Share on other sites
VWC 0 Posted August 5, 2009 Author Report Share Posted August 5, 2009 MOT'd today and passed so now time to rack up 1000miles limited to 4k rpm Link to post Share on other sites
craggsy 91 Posted August 5, 2009 Report Share Posted August 5, 2009 I feel the pain lol Link to post Share on other sites
bungy 2 Posted August 5, 2009 Report Share Posted August 5, 2009 Lovely shiney refreshed engines are so cool. Here's to the next 1000 miles. Link to post Share on other sites
john555 0 Posted August 9, 2009 Report Share Posted August 9, 2009 i bet the next 1000 miles is gona feel like its taking for ever to do, will be well worth it thou your cars gona be amazingdont suppose you have any pics of how the belt is routed around the chargers pullys as im a bit confused how it fits cheers john Link to post Share on other sites
craggsy 91 Posted August 9, 2009 Report Share Posted August 9, 2009 quite easy.....i have a pic somewhere Link to post Share on other sites
craggsy 91 Posted August 9, 2009 Report Share Posted August 9, 2009 Here ya go Link to post Share on other sites
VWC 0 Posted August 9, 2009 Author Report Share Posted August 9, 2009 i bet the next 1000 miles is gona feel like its taking for ever to do' date=' will be well worth it thou your cars gona be amazingdont suppose you have any pics of how the belt is routed around the chargers pullys as im a bit confused how it fits cheers john[/quote']Nah it aint that bad picked up 300 miles over past 4 days and by next week should be well over 500 can creep into boost in 5th gear from 40mph but then have to hold back Link to post Share on other sites
VWC 0 Posted August 9, 2009 Author Report Share Posted August 9, 2009 Here ya goThanks mate exactly how mine is done using idler pulley instead of a/cThe rule is the pulley must spin clockwise when looking at the charger from the pulley sideSee this PDF for more info on fitting http://www.rotrex.com/pdfs/Rotrex_Setup_and_maintenance_leaflet_V4.3.pdf Link to post Share on other sites
RIX 0 Posted August 9, 2009 Report Share Posted August 9, 2009 you can take a small road trip too our meet in dk,that should give you some miles iam in the prosses off getting ccr-racing too come to our meet.http://www.clubgolfdanmark.dk/news.phpalso michael is going too comehttp://www.vagcars.dk/phpbb/viewtopic.php?f=23&t=1673along vith JVK-tuninghttp://www.jvk-tuning.dk/menu/galleri/galleri_corrado.htmhttp://www.jvk-tuning.dk/menu/galleri/galleri_golf_III.htm Link to post Share on other sites
craggsy 91 Posted August 9, 2009 Report Share Posted August 9, 2009 Well I have a/c so straight forward for me Link to post Share on other sites
