Black Corrado VR6 - 400hp+ Rotrex... Updated on Page 12
pics of my corrado 2.9 vr6
SPEC:
N Plate 1995
1 previous owner bought standard at 89k now 117k
Black LC9Z
Koni Coilovers | Magnex Exhaust
ASA 8x17 Rims | 312mm 4 Motion Brakes
Recaro Black Electric Heated Leathers
Reiger Grill | Reiger Rear Window Spoiler | InPro Smoked Tail Lights
DDI Reverse Glow Clocks with Chrome Rings
Delocked | Debadged | Dewipered
  • Replies 121
I really like the dash clocks but wheres the needle??
True say. I can just about see the shadow of the speedo needle. You need them to light up in red somehow...
Thanks guys
Would be cool to get red lit needles from newer audi/vw
what i did since the pic was put the 3 bulbs at the top back in replacing the green filter with a red one so now the needles reflect better in the dark
  • 1 year later...
My Corrado is now Charged and with the Schimmel Intake & Chargecooler im getting 337bhp@7237rpm
Chargecooler is superb i didnt want to just put a charger on and then suffer warm air induction and poor running
Vince says its running as well as any charged setup he has seen i just need to see how it delivers the power on the road
Im running 12psi with MAF and fabricated ISV for stable cold idling...
Got the car back now and its awesome the numbers don’t mean a lot on the rollers as it delivers the power better on the road giving the wheels a chance and then take offs pulls really strong – with 3.68 final drive I’m always in the power band too and sounds evil :)
Here is a quick run down of the setup:
-Vortech V9 Stage Two Charger, 12psi pulley, 7 rib double sided belt
-Stealth Custom Remap with ISV & MAF / Rev Limiter advanced to 7400 rpm
-Schimmel Chargecooler with 3 Gallon Tank in boot, Pre-rad mounted in bumper
-Schimmel Shortrunner Intake - Red Top Injectors – FSE Regulator - Cosworth Fuel Pump
-Also required Braille Battery & Spal 11†& 8†Fans for Schimmel kit to fit
-Schimmel Steel Head Spacer and multi layer gaskets running lowered compression at 9:1
-Magnecore HT Leads + running standard VR6 Spark Plugs
-ARP Head & Rod Bolts
-Head & Chains overhaul last year and still good after checking this month
-Gearbox rebuilt with 3.68 Final Drive & Peloquin Limited Slip Diff
-Vibratechnic Engine Mounts
  • 5 months later...
Got my Dyno results today now fitted with a Rotrex Supercharger pushing out around 17psi – this thing is dangerous
Had it mapped a few weeks back and got 333BHP/285LB-FT but the fuelling was poor – fuelling was adjusted and pulled out 379BHP/305LB-FT with the OE Cams & just Red Tops maxxed out
Dropped in the Delphi 440’s and 263 Cams and hit 330lbs/ft@5960rpm with the main difference coming from 3000rpm and then gets stronger from there stays at 300lbs+ from 5000-7000
Will get better pics and plots in a few days - cold start idle is almost done
