henrob 0 Posted August 13, 2006 Report Share Posted August 13, 2006 I am having a power of hastle,The beast developed a weird intermitant starting problem, it would ping when you turned the ignition but persevere and it would eventually start. Wouldn't idle properly for the first 20 secs but then settle down, last night the thing went bang on starting and i got the putrid smell of burning electrics.nothing else seems affected and now its just pinging when the ignition is turned.The starter is relatively new april06, i've looked under the bonnent but can see bugger all.Any help or pointers greatly appreciated...Keith Link to post Share on other sites
duncs 0 Posted August 15, 2006 Report Share Posted August 15, 2006 HT leads? coilpack? both were a problem on mine and the problem generated a similar electricky smell. check coilpack/HT leads threads elsewhere on the board.duncs Link to post Share on other sites
henrob 0 Posted August 15, 2006 Author Report Share Posted August 15, 2006 You could be spot on with the coil pack, it looks completely buggered.I think it was the grease that was keeping it held together.I've been assured by a chap that used to work for vw that they usually just crack off the old casing clean it up a bit, slabber it in epoxy, and put on a new casing, don't know its going to work... but i'll give it an araldite bath before shelling out on a new one... Link to post Share on other sites
henrob 0 Posted August 19, 2006 Author Report Share Posted August 19, 2006 So the coil went on, cleaned up looking good as new, slabbered in about six coats of epoxy.Started first time. Idled and backfired like a pig and the died. The Battery now seems to be draining... The burning electrical smell talked about earlier was definately something else as the coil didn't smell at all. A bit freeked now because the dash computer display is now bonkers. got a vag com cable hopefully next week, but any pointers would be appreciated.Keith Link to post Share on other sites
henrob 0 Posted August 27, 2006 Author Report Share Posted August 27, 2006 vag com, cable arrived and fired up on the laptop, engine only displayed one fault engine speed sensor faulty or no signaldont know how this could be responsible for the battery drain..its an 95 OBD1, can anyone tell me where its located?cheers, Keith Link to post Share on other sites
