Finally got my vr up and running with stage 2 vf supercharger on monday and am very happy with the results.
Only problem that I am having is that after motorway drive or driven hard when coming off WOT it can occasionally stall.
Noticed it more today as done a fair bit of motorway driving and whenever I came off the motorway the engine would stall and would take a few a minutes of town driving to correct itself.
Has any other supercharged vr owners had this problem?
Fitted to obb1 car with custom code map.
Will try cleaning out throttle body. But done that when renewed timing chains and clutch 3 months ago.
MAF is just installed between filter and charger using orignal housing and with pipework supplied in s/c kit.
Only way to move it further from charger would be make up new housing for MAF.
As for diverter valve do you mean blow off valve?
If so then yes alloy recirculating valve fitted.
