Retro_J 0 Posted August 31, 2006 Report Share Posted August 31, 2006 Hey just wondering if someone can help with a misfire on my 137k 1994 VR6 Golf (OBD1). It seems to miss every so often when warm. The car was recently serviced, and has brand new plugs as well as 6 month old leads. It wont misfire when cold (oil temp below 70oC) and also doesnt do it when sitting idling or under heavy accelaration. Any help on this would be appreciated, cheersJ Link to post Share on other sites
jpc 0 Posted August 31, 2006 Report Share Posted August 31, 2006 most likely your coil pack, look for cracks in it, this causes the same symptoms Link to post Share on other sites
Seademon 0 Posted August 31, 2006 Report Share Posted August 31, 2006 My car had similar probs which turned out to be a loose plug (or 6) - if yours is OBD1 you wont have a coil pack but check your dizzy cap and arm. Mine tended to this more when it was hot or after a shoeing with the gas pedal when the engine wasnt running so hot. Link to post Share on other sites
6potmkII 0 Posted August 31, 2006 Report Share Posted August 31, 2006 i would first check your dizzy and rotor arm, and replace them for piece of mind, and which leads did you buy 6months ago? ud be lucky for cheap leads to even last you that imo.... so it may well be them again Link to post Share on other sites
dellert 0 Posted August 31, 2006 Report Share Posted August 31, 2006 i would first check your dizzy and rotor arm' date=' and replace them for piece of mind, and which leads did you buy 6months ago? ud be lucky for cheap leads to even last you that imo.... so it may well be them again[/quote']Mine is ODB1 with coil pack, so not strictly true.Also check your plug condition, and tightness. Mine worked loose and I got a slight miss. However do not overtighten as you will be in trouble if you strip the thread! Link to post Share on other sites
apd 0 Posted August 31, 2006 Report Share Posted August 31, 2006 if its 94 probably has a coilpack[hate to be pedantic!] Link to post Share on other sites
Seademon 0 Posted September 1, 2006 Report Share Posted September 1, 2006 Not if its OBD1 surely but im no expert Link to post Share on other sites
johnemerson38 1 Posted September 1, 2006 Report Share Posted September 1, 2006 i have got OBD1 and thats got a coilpack on it and mine had a huge crack in it just got a new one now its fine Link to post Share on other sites
IbiVR 0 Posted September 1, 2006 Report Share Posted September 1, 2006 Not if its OBD1 surely but im no expert OBD1 was coilpack from mid 93.ECU codes for Dizzy OBD1 are 021 906 258 A/B/CECU codes for the coilpack ODB1's - 021 906 258 AG/AF/CH/CP/BM/EA/BKOBD2 codes are 021 906 256 XX or 02 1906 259 XXDefinatly worth checking. have a good look for cracks on the black plastic.Tom. Link to post Share on other sites
Retro_J 0 Posted September 1, 2006 Author Report Share Posted September 1, 2006 Cheers for all the help guys, gonna have a look at the leads and coil. At least its not like the Mk1 lol, cheersJ Link to post Share on other sites
