Starting problem, lumpy idle
Right my rado struggles to stay running when you start it from cold. You have to keep the revs up to keep it running otherwise it just stalls! After its been running a minute or two ,stalling a couple of times it idles but lumpy!
Seems to pull fine and has had lots of parts already replaced :
(SECOND HAND)
COIL PACK
MAF
ECU
INJECTORS
(NEW PARTS)
OE LEADS
PLUGS
BLUE TEMP SWITCH
CAM POSITION SENDER
THROTTLE POSITION SENSOR
FUEL FILTER
Once the car is running and idling it may cut out occasionally at a junction but the idle seems to drop fairly well. Ive checked that the relays are clicking. They click twice before the key is turned fully with a final click. Ive checked it for air leaks using brake cleaner around the intake/ pipes etc. I have had it on VAG-COM recently when it had this problem and it didn't show anything. I haven't had it on there lately but I will in the next week or so. I have thought maybe fuel pump ,but it doesn't seem to make that much noise ,but I can here it.
Would the big yellow temp switch have anything to do with the cold start or running? My dad has ordered a new black and yellow sensor for me anyway!
Any advice would be much appreciated as I haven't got much hair left!
Try puting a jump lead between your negative battery terminal and a good clean bit metal on your engine. could just be a bad earth. although a vacum hose wouldn't cause to much probs from a small pipe far away from the manifold but if its a big leak it would cause the idle to be irratic. check the brake servo pipe and inlet manifold gasket but it sounds like an engine management problem to me.
Right!!!!
His car is ODB1' date=' so no stepper motor, so no buzzing.
The pipes under the airbox are a fuel vapour and a vacum hose......they wont make the car run like crap.
ok about the the obd1 i didnt know if it was the same but im telling theres a hose/pipe than runs next to or under the air filter pipework when it splits its runs like a 3 legged donkey i know as it happened to me when i fitted the schrick
I think Ive found the problem!
After taking the ISV off again to give it another clean I noticed it is actually seized almost shut or open? You can get a screw driver in the top but it doesn't budge at all. Hopefully this is the cause of the problem and then I can start enjoying my new mods and stop complaining about the running!
But theres always something else to move onto eh !
How much is it supposed to open?
