Angel Eyes..
Ok so Winter is coming. I have read the links and feel I will go for the Angel eye set up by hella. (just to see better of course :o ) Just want to ask for one final check. So a quick question to those who have them!
If bulbs / lenses etc go are they easy to fix and parts available? Also can I put any old bulb/lamp in them. I want to get to that Xenon look.
Finally has anyone had issues of note and did you have to get them readjusted after fitting?
Cheers and thanks as always Ladies and Gents
Rod
The main bulbs are standard types, can't remember the size/# but think they are the same as normal. I doubt the LEDs in the rings are replaceable but should last for a long, long time having no filaments to burn out. I've got some lense covers from VW to protect them from stone chips.
I had to get mine adjusted but my car was in the garage when they arrived and I couldn't help playing! It will also depend on the stance of your car. Park up facing a wall and mark the light spots so you can check once you swapped the lamps.
My only issue is that because I drive with them on all the time, I am prone to leaving them on and flattening my battery (I don't have a buzzer).
TG
