In Theory yes! It should be a straight swap, but does the engine come with all the wiring/Ecus Etc?? B) ?! just a precaution that's all, incase you need parts etc.
Good Luck, Hope you win! :D;) 8o)
[ Edited Fri Jun 18 2004, 04:20AM ]
i think i know the one you're tallki about...it doesn't include ecu does it?
i reckon you should take everything off it at the manifolds, and use your current stuff...and in my mind that should work. it'll then be an obd1 engine.
