VR6gaz 0 Posted September 30, 2006 Report Share Posted September 30, 2006 im pretty sure (could be wrong) that cats came in on the K plate.does this mean i can run a mk2 vr with no cat? or does it apply to the year the engine was made? Link to post Share on other sites
thegoth 5 Posted September 30, 2006 Report Share Posted September 30, 2006 It's the oldest of the chassis or the engine which controls the emissions levles at MOT :-) Link to post Share on other sites
Chrisdut 0 Posted September 30, 2006 Report Share Posted September 30, 2006 nah its the date of reg that controls the emissions test, 93 onwards is a cat test Link to post Share on other sites
Chris Evans 0 Posted September 30, 2006 Report Share Posted September 30, 2006 yeah you are right! you can run the mk2 vr without a cat. get a nice increase in power at the same time! Link to post Share on other sites
thebluebus 0 Posted January 5, 2007 Report Share Posted January 5, 2007 3rd'd. you can run cat-free! Link to post Share on other sites
lee060 3 Posted January 6, 2007 Report Share Posted January 6, 2007 i thought it was 94 on that needed cat :S , lol only a year off so pretty close Link to post Share on other sites
Russ_vr6 12 Posted January 6, 2007 Report Share Posted January 6, 2007 june 1993,i checked with the mot guy at work 4 ya Link to post Share on other sites
VR6gaz 0 Posted January 8, 2007 Author Report Share Posted January 8, 2007 june 1993' date='i checked with the mot guy at work 4 ya [/quote']cheers! Link to post Share on other sites
ventovr6essex1 0 Posted March 25, 2007 Report Share Posted March 25, 2007 infact its about july 1995 cant rember the date exactly . but the loop hole is that you have to beable to read the engine code . how it works is you carry out what is called a bet test on cars after 8/92 if it fails to put in car details ie make, model and the all important engine code ! you have to see the engine code with you own eyes . if you cant find it you have to carry out a non cat test . my car was registered 06/95 and it falls into this loop hole . your car would still be non cat test because of the age of it . but also if you had a 2000 rangerover v8 and you put an old v8 on carbs in it and you could prove the age of the engine it would infact be non cat test . ive found this but im sure they have changed it since this . on monday i will look fon the computer . http://www.vosa.gov.uk/vosacorp/repository/7.3%20Emmissions%20-%20Spark%20Ignition%20-%20Passenger%20Cars%201992-2002.pdf#xml=http://www.vosa.gov.uk/SCRIPTS/texis.exe/webinator/search/xml.txt?query=emissions++&pr=CORP&order=r&cq=&id=4606021321 Link to post Share on other sites
