VR6Pete 1,455 Posted October 3, 2006 Report Share Posted October 3, 2006 I've just realised that the filter element in the BMC's are washable!With over 3 years of dirt and grime in the element I removed the filter element from the carbon canaster case and I gave it a bash in the sink and literally a pile of crud came out. I then washed some warm water through it and more crud came out, I then left it to soak in some warm soapy water and then swirled the air filter element about in the sink the water was black at this stage. I then ran more warm water through the element taking care to to remove all soap suds and dryed it off with my hair dryer (low setting) (yes, I am male and own a hair dryer!) I then gave it a bang against the palm of my hand and to my suprise, more dust and rements of dead fly's and leaves fell out, once no more crud fell out, put it all together and stick it back on the car and...ENJOY! The car now sounds a little more grunty and has regained it's roar which had faded away over time.. Obvously I cant take it over 3,000 RPM with running it in, but I can already feel the differance a good clean can make.Give it a go, what have you got to loose?Pete Link to post Share on other sites
VR6_Absy 0 Posted October 3, 2006 Report Share Posted October 3, 2006 I've been thinking about doing mine for some time but just haven't got around to it. I don't personally own a hair drier, will have to borrow the missus ;-) Do you recommend fairy liquid to creat the bubbles ;-) lmao Link to post Share on other sites
cadguy77 0 Posted October 3, 2006 Report Share Posted October 3, 2006 are you using the CDA on a charged setup? Link to post Share on other sites
VR6Pete 1,455 Posted October 3, 2006 Author Report Share Posted October 3, 2006 are you using the CDA on a charged setup?If its compatable, then ideally I'd like to keep it Link to post Share on other sites
The_0ne 0 Posted October 4, 2006 Report Share Posted October 4, 2006 My friend ran a BMC on her supercharged Focus without problems Link to post Share on other sites
mk3anni 0 Posted October 4, 2006 Report Share Posted October 4, 2006 My friend ran a BMC on her supercharged Focus without problems Thats lovely.Space is very limited on the Vr with the charger installed, I think you'll have space issues pete, in fact I'm almost certain it wont fit!!! Link to post Share on other sites
The_0ne 0 Posted October 4, 2006 Report Share Posted October 4, 2006 Just locate it behind the bumper, it isn't hard Link to post Share on other sites
mk3anni 0 Posted October 4, 2006 Report Share Posted October 4, 2006 You have no idea, I have a charger kit, i knoww how the pipe work sits because i fitted the charger myself, and I cant see it fitting. Link to post Share on other sites
VR6Pete 1,455 Posted October 4, 2006 Author Report Share Posted October 4, 2006 on second thoughts, I doubt it will fit, with all the air con stuff too. Link to post Share on other sites
shail 0 Posted October 8, 2006 Report Share Posted October 8, 2006 I just gave mine a power shower after removing the filter from inside - couldn't belive the amount of crap that came out & the number of flies. I even got a silk cut fag end out of it! Link to post Share on other sites
matth76 1 Posted October 8, 2006 Report Share Posted October 8, 2006 Why do you have to run it in after cleaning the filter? Link to post Share on other sites
