carbon canister
  • 2 years later...
i just want to make sure i get this right, the canister can be removed with no adverse affects to the car, and to do so i remove it via the drivers side arch with a screw than block the black pipe and feed the clear under the arch to vent. if its fuel fumes, can u not just link the black and the clear together to route the fumes back into the engine? or am i being stupid? also wont that make your car smell of petrol when you drive it if your venting fumes to the wheel arch?
im onkly asking as i want to run the induction pipe through where the canister is to l;ocate the filter in the bottom of the arch behind the little grill in the bumper
