Special K 0 Posted October 10, 2006 Report Share Posted October 10, 2006 Are these 2 pot calipers? Will they fit on my vr under 15inch wheels? Will I be able to keep my ABS?Cheers Link to post Share on other sites
wayne_1@tiscali.co.uk 27 Posted October 10, 2006 Report Share Posted October 10, 2006 yes they are 2 pots and should fit under your 15s Link to post Share on other sites
Special K 0 Posted October 16, 2006 Author Report Share Posted October 16, 2006 From a bit of research these apparently these bolt straight. I am wooried about the disc sizes though - What exactly is the hub diameter?VOLKSWAGEN Golf/Jetta 2.8 VR6 91-95 Front Vented DiscsNo of Bolt Holes : 5Diameter : 280Hub Diameter : 150Height : 29New Thickness : 22Minimum Thickness : 20AUDI S2 2.2 Turbo 91-96 Front Vented DiscsNo of Bolt Holes : 5Diameter : 276Hub Diameter : 147Height : 56New Thickness : 25Minimum Thickness : 23 Link to post Share on other sites
mk3anni 0 Posted October 16, 2006 Report Share Posted October 16, 2006 Bolt straight on to what???Dont forget the later VR's had a different brake setup to the early ones. Link to post Share on other sites
