mike 6 Posted October 14, 2006 Report Share Posted October 14, 2006 Almost every time i drop a gear to go faster or some times just changing up while driving fas it pops. slight backfirewhat can cause this? hope my exhasust and knackered its full magnex about 2 or 3 years old Link to post Share on other sites
stockers 1 Posted October 14, 2006 Report Share Posted October 14, 2006 i had a magnex on my old vr, they do seem to be very poppy. although it is odd that it pops while changing up gears(unless you are changing gears really slowly ) as the popping is excess fuel that combusts in the exhaust when the car engine is slowing and doesn't need as much fuel , it shouldn't have excess fuel if you are accelerating i don't think.....although i may be wrong Link to post Share on other sites
Luke 0 Posted October 14, 2006 Report Share Posted October 14, 2006 Almost every time i drop a gear to go faster or some times just changing up while driving fas it pops. slight backfirewhat can cause this? hope my exhasust and knackered its full magnex about 2 or 3 years old does the car feel abit slower than usual or maybe not quite runnin right(only slighty though)? my car started doin just wot urs is & over a few weeks the performance started 2 die off & woz runnin sh*t, turned out 2 b cam sensor fu*kin it up, replaced it job dun Link to post Share on other sites
mk3anni 0 Posted October 14, 2006 Report Share Posted October 14, 2006 Mine does that but mines charged so its to be expected.I doubt you have a problem but slap it on vag com just in case. Link to post Share on other sites
rodney 17 Posted October 15, 2006 Report Share Posted October 15, 2006 Other than the things mentioned. When changing a gear and you get a pop it can be due to a slight misfire/timing slightly off. So It's worth getting that checked out also.(Cost Aston Martin the Win at Le Mans - One where they ran out of fuel- 2005 I think - as it uses more fuel.......)Is your fuel consumption slightly worse??Hope these all help Link to post Share on other sites
crish72 0 Posted October 15, 2006 Report Share Posted October 15, 2006 Mine pops at low speeds and on idle...sounds great :-)I've put it down as an exhaust trait as there are no faults.Chris Link to post Share on other sites
VR6_Absy 0 Posted October 15, 2006 Report Share Posted October 15, 2006 Mine pops like fork when letting my foot off the accelerator but i'm putting mine down to needing a remap after all the tweaks ;-) Link to post Share on other sites
mike 6 Posted October 18, 2006 Author Report Share Posted October 18, 2006 had not considered it to be overfuelling, theve just opened up a rolling road at midland vw so might take it down there to check the timing Link to post Share on other sites
mike 6 Posted October 19, 2006 Author Report Share Posted October 19, 2006 just realsied i fitted an OBD1 air intake to my obd2 car oops, have swapped it back and havent heard any poping since, so hopefully that was it. Link to post Share on other sites
