The Punisher 0 Posted October 23, 2006 Report Share Posted October 23, 2006 Hi all Good news everbody, i got my brakes working at the weekend all system totaly air free and brake pedal is nice and firm. Bled the clutch master cylinder and the clutch system using the bleed nipple on the gear box all ok my problem is the clutch pedal once pressed does not come back up it stays down. what should move the pedal up is it the clucth releasing? moving the fluid back through the system pushing the master cylinder inturn pushing the pedal or does the master cyclinder do it all by itself or is it the spring at the top of the pedal? Thanks All Joel PS have recently put new clutch in Link to post Share on other sites
The Punisher 0 Posted October 23, 2006 Author Report Share Posted October 23, 2006 addition i think i havnt bled the clutch right i need a power bleeder ??J Link to post Share on other sites
dellert 0 Posted October 23, 2006 Report Share Posted October 23, 2006 I bled mine using a One man bleeding kit that uses pressure from a spare tyre, worked really well, let the tyre down first though, only needs a few PSI, else it pisses out fluid everywhere!!! Link to post Share on other sites
