P262YUD 0 Posted November 18, 2006 Report Share Posted November 18, 2006 Hi, I have recently had my golf vr6 lowererd using the Eibach lowering springs. The drop was by 30-40mm.The front end does not seem to have dropped and the camber of the wheels point inward at the bottom, making the car skittish.i've tried having the tracking done, but no difference.Any ideas? Link to post Share on other sites
mannie 0 Posted November 18, 2006 Report Share Posted November 18, 2006 You need to have your front CAMBER/TRACKING reset. Link to post Share on other sites
Russ_vr6 12 Posted November 19, 2006 Report Share Posted November 19, 2006 also by lowering mate it will put more pressure on any tired bushes like lower arm bushes etc which wont help either Link to post Share on other sites
P262YUD 0 Posted November 19, 2006 Author Report Share Posted November 19, 2006 Thanks for that, will have all bushs checked out. would new standard shocks help?? Link to post Share on other sites
stuey 0 Posted November 20, 2006 Report Share Posted November 20, 2006 You ideally need an uprated shock to go with the springs, as the spring rate is increased 20ish percent. Link to post Share on other sites
