sparkz 0 Posted May 1, 2007 Report Share Posted May 1, 2007 Do it!!!!!! Link to post Share on other sites
bigleem 0 Posted May 2, 2007 Report Share Posted May 2, 2007 Wise words from sparkz! :-d i'm a bit bias on that front though :-p Link to post Share on other sites
vdubgirl 3 Posted September 4, 2007 Author Report Share Posted September 4, 2007 Woo Hoo I still have the VR6 bug and I'm now on the look out for a VR6 donar car so I can pillage it for all the bits i need to turn Jerry into a VR6 Beastie Link to post Share on other sites
VR6Pete 1,455 Posted September 4, 2007 Report Share Posted September 4, 2007 im currently about to do a mk2 vr6 conversion. pete Link to post Share on other sites
vdubgirl 3 Posted September 24, 2007 Author Report Share Posted September 24, 2007 Woo Hoo I've got all the bits i need to do my conversion now - Project diary is here - http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?196854 Link to post Share on other sites
vdubgirl 3 Posted December 28, 2007 Author Report Share Posted December 28, 2007 Wow one year later I have my Mk2 VR6 http://s28.photobucket.com/albums/c242/G60dave/?action=view¤t=24112007074.flv Still working on Jerry but not much more to go now until he;'s fully back on the road Link to post Share on other sites
muttley 0 Posted August 7, 2010 Report Share Posted August 7, 2010 ok i've got a quick question.i have a 90's spec 8v gti and i'l be using a Vento VR6 as the doner carI'm thinking about changing it to cable change so i dont have to mess about cutting holes in my bulkhead.I'm going to keep the mk3 track so i'l be using most of the mk3 stuff and the petrol tank (if needed).what else do i need coz i've been reading / hearing conflicting info ie in regards to corrado parts neededsome people have siad i can use the cross member and radiator from the vento but other people have been saying that this is wrong and i need to source corrado cross member radiator and fans.please help coz i want to get started on this soon as i need room as the vento is taking up my garage.if anyone can think of anything i've missed or anything that will help me any info will be grately appreciated Link to post Share on other sites
golfrabbit33 0 Posted August 7, 2010 Report Share Posted August 7, 2010 i have a corrado VR6 (the correct one) cross member spare, you can have it for the £70 i paid for it.. Link to post Share on other sites
gavinvr6 0 Posted August 7, 2010 Report Share Posted August 7, 2010 the cross member can be either mk2 golf or corrado. the fands and rad fit from mk3/rado/vento vr's but the mk3 and vento ones need slight modding to fit. also if going cable clutch you can buy a conversion kit from tsr for 125 quid. it uses seat o2a clutch cylinder and bracket and golf 1.3/1.6 cable,try to find a cable the same but stronger as a few hard launch's will snap the cable. i may go cable clutch if i can get the part numbers then im going to get a tougher cable made. vr pressure plates are propper heavy duty apposed to the golf cable you would need to use hence the need to keep a couple of spares in the boot Link to post Share on other sites
Jordz 0 Posted August 7, 2010 Report Share Posted August 7, 2010 Cutting the hole in the bulkhead is easy, just put in the pedal box, mark it, and drill away. The actual cylinder is quite flexible on the piston rod so it allow for some amount of error. You would need a raddo pedal box I believe to make it easier, but I just did a bit of modification to the mk2 pedal box and it works fine. Link to post Share on other sites
gavinvr6 0 Posted August 7, 2010 Report Share Posted August 7, 2010 how do you mod the mk2 pedal box to run hydrolic clutch? Link to post Share on other sites
muttley 0 Posted August 7, 2010 Report Share Posted August 7, 2010 ^^ x2 Link to post Share on other sites
golfrabbit33 0 Posted August 7, 2010 Report Share Posted August 7, 2010 use a vr6 rado one Link to post Share on other sites
muttley 0 Posted August 7, 2010 Report Share Posted August 7, 2010 use a vr6 rado one ok does it have to be out of a VR rado or will a 16v one do? also do i need anything with it?i@m going to go shopping on the bay but need to know before i do it Link to post Share on other sites
golfrabbit33 0 Posted August 7, 2010 Report Share Posted August 7, 2010 no,must be vr rado. rocking horse poo,as you will find out Link to post Share on other sites
Jordz 0 Posted August 8, 2010 Report Share Posted August 8, 2010 Em to mod the mk2 one, presuming its a mk3 donor car, you have to swap the clutch pedal from the vr onto the mk2 pedal box (bit fiddly but easy enough). Then you have to extend the runner for the spring, and also get a longer spring (B&Q).Hope iv explained it ok-its easy to see when you do it. The hardest part is getting the pedal to come back down, hence needing the bigger spring Link to post Share on other sites
Tattoomang60 0 Posted August 4, 2013 Report Share Posted August 4, 2013 I'm now about to inbark on building a mk2 vr track car need all the help I can get Lol *-) Link to post Share on other sites
