HI all
Been having some clutch problems the pedel was rock solid....Well last night i got the box out and saw id made a right cock up when i put the thrust bearing back in basically it was all in backwards anyways ... have a look at this picture i think i am missing something.. is there something that should fit into the concave bit of the slave cylinder that alows the leaver with the thrust bearing to be pushed when the pedel is pressed... does that make sence?? lol
Thanks
Joel
You don't say what motor or year. By the looks of the pic, there would be no clutch operation at all. Cant really tell what i'm looking at, apart from the release arm, which looks like it should have a piston to operate the bearing.
What's the pedal like now you've sorted the bearing?
