crish72 0 Posted December 10, 2006 Report Share Posted December 10, 2006 God knows what it is but when i first start my VR from cold i get what i can only describe as a whirring noise coming from the engine. It seems to go up and down with the revs and stops after say 3-4 minutes.Had a quick skeg under the bonnet today but couldnt see anything obvious,if anything it sounded like it came from the back of the engine.Anyone else had this or can shed any light?CheersChris Link to post Share on other sites
mk3anni 0 Posted December 11, 2006 Report Share Posted December 11, 2006 Dunno, but mines always done it too!! Link to post Share on other sites
shail 0 Posted December 11, 2006 Report Share Posted December 11, 2006 Does it sound a bit like a milk float? Mine does this, it gets worse as the weather gets colder. Link to post Share on other sites
crish72 0 Posted December 11, 2006 Author Report Share Posted December 11, 2006 Does it sound a bit like a milk float? Mine does this' date=' it gets worse as the weather gets colder.[/quote'] Yep ,that's just what it sounds like - an electric milk float!!Must be common then...Chris Link to post Share on other sites
wkd928 0 Posted December 11, 2006 Report Share Posted December 11, 2006 yeah, mine too. Link to post Share on other sites
richievr 1 Posted December 11, 2006 Report Share Posted December 11, 2006 i think they all do it.i leave mine idling and don't drive it till it stops..no particular reason - i just do..gives it a chance to warm up slightly and for the oil to get everywhere before moving it.. Link to post Share on other sites
Jk* 0 Posted December 11, 2006 Report Share Posted December 11, 2006 Mine also does it, just let the car warm up as much as possible before driving it...or change gear @ 2500rpm max for me! Link to post Share on other sites
crish72 0 Posted December 11, 2006 Author Report Share Posted December 11, 2006 Cheers fellas,that's put my mind at ease anyway. Chris Link to post Share on other sites
Russ_vr6 12 Posted December 11, 2006 Report Share Posted December 11, 2006 mine too,i think could be the power streering pump,coz my mates old vr used to do it all the time but worse,so i think its just the pump pushing the fluid round Link to post Share on other sites
GVK 1 Posted December 11, 2006 Report Share Posted December 11, 2006 Mine does that too, I replaced the belt tensioner, but it still does it.Goes once warm tho! Link to post Share on other sites
spindat45 0 Posted December 11, 2006 Report Share Posted December 11, 2006 Mine too. I've put it down to alternator complianing at having to go to work in the cold. :-d Not a problem as long as it goes after a few minutes idling. Definatly only noticeable as it starts to get cold. Whatever the cause, its good to know its an inherant feature of these great engines.Kevin Link to post Share on other sites
stockers 1 Posted December 11, 2006 Report Share Posted December 11, 2006 yep me too, i got a feeling its the choke effect, when you start it let it run til the choke cuts off and the idle sits at normal level and it won't happpen..... Link to post Share on other sites
Dima 1 Posted December 12, 2006 Report Share Posted December 12, 2006 Mine does it as well, Im releaved now to hear its kinda normal thing Link to post Share on other sites
jpc 0 Posted December 20, 2006 Report Share Posted December 20, 2006 This has always annoyed me I thought something was wrong until I heard a cold 2L mk3 go past me and guess what? The same whine, they both must share the same bit that makes the noise I guess. Link to post Share on other sites
purple highline monster 0 Posted December 21, 2006 Report Share Posted December 21, 2006 lol mine does it too, guess its just a characteristic of the cars belt set up, its only when its cold it happens though Link to post Share on other sites
tinny22 11 Posted December 21, 2006 Report Share Posted December 21, 2006 mine to.thats put my mind at rest its a horrible sound.many years ago i was a milkman 4am every morningtinny22 Link to post Share on other sites
katconcarne 0 Posted December 21, 2006 Report Share Posted December 21, 2006 my power steering pump does this! Link to post Share on other sites
ingham 5 Posted December 21, 2006 Report Share Posted December 21, 2006 its the oil pump making the noise(cold oil is thick) ,thats way you notice it more in winter...ps is normal Link to post Share on other sites
VR6Pete 1,455 Posted December 21, 2006 Report Share Posted December 21, 2006 All VR's make a wirring noise when cold, I wouldnt be too concerned...Pete Link to post Share on other sites
Eat this 2 Posted December 21, 2006 Report Share Posted December 21, 2006 its 1 of the very few noises i take no notice of hehe Link to post Share on other sites
Russ_vr6 12 Posted December 21, 2006 Report Share Posted December 21, 2006 i like it sounds like its charged lol Link to post Share on other sites
Bigjobbo 0 Posted December 21, 2006 Report Share Posted December 21, 2006 Just for the record, mine does it too. Link to post Share on other sites
spanky 0 Posted December 22, 2006 Report Share Posted December 22, 2006 Yep, mine too!! Link to post Share on other sites
matty 0 Posted December 31, 2006 Report Share Posted December 31, 2006 It's usually the alternator providing lots of Amps to the battery just after cold start up when the charging system thinks the battery is low.The output from the alternator can then be 50 or 60 amps and the windings "flex" under the high current for a bit until the battery charges up to voltage.If the fan belt is slack on most cars it slips and squeals just after a cold start for the same reason.My son's VR6 has also been making this noise since the Wintery weather came and I think and hope its a natural function of the alternator !!!Matty. VINCENT COMET 500 (that's my bike). Link to post Share on other sites
