nickvr 0 Posted December 11, 2006 Report Share Posted December 11, 2006 gonna service the brakes new pads an discs all round any recommendations? also whats the best way to get the pistons back in the calipers without damaging them?cheers Link to post Share on other sites
Bigjobbo 0 Posted December 11, 2006 Report Share Posted December 11, 2006 you need a piston winding tool really, but if your strong as fcuk, you can sometimes get them in with a pair of long nose pliers and a bit of elbow grease. It's a bit yeehaw though!!If your car is modified and you want to stop quicker, uprate the lot, otherwise just stick with the standard set up. Search the previous threads too. Link to post Share on other sites
nickvr 0 Posted December 11, 2006 Author Report Share Posted December 11, 2006 why are they screw in pistons? tryed winding an they didnt seem to move it!? mk3 vr btw Link to post Share on other sites
Petesvw 0 Posted December 11, 2006 Report Share Posted December 11, 2006 You can use large water pump pliers on the fronts with no risk of damage! But yes the rears need to be turned back!It's not uncommon for 'em to be siezed mate, this may be why they wouldn't wind! Link to post Share on other sites
nickvr 0 Posted December 12, 2006 Author Report Share Posted December 12, 2006 no they did turn but pretty sure they didnt wind in!? how fine is the thread? how many turns till there fully in?cheers Link to post Share on other sites
mk3anni 0 Posted December 12, 2006 Report Share Posted December 12, 2006 Fronts need pushing in, I usually just use a G clamp.The rears you need to wind in using the wind back tool, about £15 from GSF. Its quite a few turns i THINK, i remember it took a little while even with an impact gun.I run stock disks all round with pagid fast road pads. Stops rather well!!! Link to post Share on other sites
nickvr 0 Posted December 12, 2006 Author Report Share Posted December 12, 2006 spot lads nice one. just befire i go can i fit the 288mm disks instead of the 280mm ones or will the calipers need to be changed aswel? Link to post Share on other sites
Petesvw 0 Posted December 12, 2006 Report Share Posted December 12, 2006 You need calipers and carriers mate afaik. Link to post Share on other sites
nickvr 0 Posted December 12, 2006 Author Report Share Posted December 12, 2006 cool. stick with standards then cheers for all ya help Link to post Share on other sites
craggsy 91 Posted December 12, 2006 Report Share Posted December 12, 2006 Big G clamp for me.....works a treat Link to post Share on other sites
Petesvw 0 Posted December 13, 2006 Report Share Posted December 13, 2006 Got a 288 set up for sale dude ; ) Link to post Share on other sites
jims13 6 Posted December 13, 2006 Report Share Posted December 13, 2006 best place to get the pads is???? after some uprated ones for the road/ring Link to post Share on other sites
mk3anni 0 Posted December 13, 2006 Report Share Posted December 13, 2006 Pagid fast roads from GSFI swear by them Link to post Share on other sites
nickvr 0 Posted January 3, 2007 Author Report Share Posted January 3, 2007 can i put a 288mm setup straight on my vr? i mean regarding the pipework or will i need new flexi'scheers Link to post Share on other sites
nickvr 0 Posted January 4, 2007 Author Report Share Posted January 4, 2007 any ideas?? Link to post Share on other sites
