i want to remove my air con as i have no need for it, and it costs extra on fuel, takes power away from engine and adds weight from what i understand, all for a bit of cold air. is it easy to remove? anyone had it removed and a what cost? or do you think i should leave it in, and lastly will i depreciate the car value if i take it out?
thanks alot guys
weather its climatronic or not you can turn the air con off, it just switches off the electromagnetic clutch in the compressor, the pulley wheel still turns but nothing inside turns while its switched off, i wouldn't remove as you have to remove the dash to remove the heater box so u can fit a none air con system, that said if you do want to take it out can i have first dibs please ;)
