Sounds like a HT / spark problem. Check for sparks coming out of your coil pack around where the HT leads go in to it(common problem, as the coil pack casing cracks causing arcing). Mine was doing this yesterday after it had been stood for a week. A run up an A road sorted it as it got rid of the damp.
If you do see sparks when the engine is on, do a search on here for 'coilpack' and you'll find a whole load of useful info.
I'd also do a search for 'MAF' as a dodgy MAF can cause symptoms similar to the ones you describe.
