Temp Gauge (engine coolant) not working.... any ideas?
The temp gauge for engine coolant (on the instrument cluster, left hand side) is dead.
Replaced the two switches found on the thermo housing - one of them was the engine coolant temperature sensor, the other was the thermo sender for ECU. Replacing these items hasn't solved the problem.
The only other 2 things I can figure out are either the thermostat is knacked or the actual gauge on the instrument panel is knacked.
The car drives fine, engine oil temp sits at 90 degrees most of the time, no leaks either and the heating works perfectly.
Any ideas?
Anyone else had this problem?
main thermostat housing - 021 121 117A - £22.45 + vat
seal to join to head - 021 121 119A - £2.28 + vat
connector to water pipe - 021 121 133D - £9.45 + vat
connector to pipe seal - N101 392 01 - £1.48 + vat
thermostat cover - 021 121 121A - £9.45 + vat
thermostat (80deg) - 075 121 113D - £11.50 + vat
thermostat seal - N901 368 02 - £2.15 + vat
temp sensor seals - N903 168 02 - £0.87 +vat
Or from a ford Dealer:
main thermostate housing - 1032250 - 21.74 + vat
head seal - 1022692 - 1.51 + vat
connector to pipe seal - 1018807 - 0.80 + vat
temp sensor seal - 7198663 - 0.63 + vat
connector to water pipe & therm cover ( can't tell which is which from my invoice ) - 1032251 & 1032252 - 7.64 & 7.79 + vat
Prices at April '06
my breather valve ( 7364573 ) was 20.54 + vat (Jul 06)
get someone sitting in the car with the ignition on, take the plug off the switch and bridge the contacts in pairs. When you bridge the right two the gauge will shoot up, that cancels out your fuse, and points to the switch. Unlikely to be the gauge itself.
Is it definately the temp sender switch you changed?? What about the fan switch? Does the fan come in?
The stat could be the cause, but once your oil temp hits 90, your coolant would still be running at about 70 with the stat stuck open, so this would still op the gauge.
To check the wiring, bridge test it. A mech would check that circuit first.
Good luck
