petervr6 0 Posted January 11, 2007 Report Share Posted January 11, 2007 hi peeps ok got a small problem ONLY every now and then my car start and then dies stright away it does it about 9 times one after the other then it will finally start normally any ideas what this could be?cheers peter Link to post Share on other sites
kalv 0 Posted January 12, 2007 Report Share Posted January 12, 2007 Is this from first time in morning when cold..? Coolant sensor? Link to post Share on other sites
richievr 1 Posted January 12, 2007 Report Share Posted January 12, 2007 most likely immobiliser . . . Link to post Share on other sites
clarkie 1 Posted January 12, 2007 Report Share Posted January 12, 2007 this is what mine is doin but mine wont go at all Link to post Share on other sites
Petesvw 0 Posted January 13, 2007 Report Share Posted January 13, 2007 You had coilpack and fuel pump relay checked? Link to post Share on other sites
petervr6 0 Posted January 13, 2007 Author Report Share Posted January 13, 2007 to be hounest i havent checked anything but it does seem to be when the engine is cold but i did change the the temp sensor about 8months ago(thats the blue one) but i was also thinking myself that it could be the alarm playing up if i put it on a vag-com should this show the faults ov if its the alarm it wount but if its any thing to to with the relays etc? Link to post Share on other sites
petervr6 0 Posted January 13, 2007 Author Report Share Posted January 13, 2007 most likely immobiliser . . .richie your car is looking sweet matey. the colour of the new leather work very well with the colour of the car. Link to post Share on other sites
mk3anni 0 Posted January 13, 2007 Report Share Posted January 13, 2007 Immobiliser Link to post Share on other sites
Petesvw 0 Posted January 14, 2007 Report Share Posted January 14, 2007 Is it a factory fit alarm? Link to post Share on other sites
mulberry man 0 Posted January 14, 2007 Report Share Posted January 14, 2007 does it still do it if you press the throttle at the same time as tou start it? mine did the same thing so i clened the throttle body and maf and it started perfectly. Link to post Share on other sites
Jk* 0 Posted January 14, 2007 Report Share Posted January 14, 2007 MAF? Link to post Share on other sites
petervr6 0 Posted January 15, 2007 Author Report Share Posted January 15, 2007 does it still do it if you press the throttle at the same time as tou start it? mine did the same thing so i clened the throttle body and maf and it started perfectly.yes still does it even if you try pressing he throttle at the same time and the alarm isnt factory its an autowatch after market when it does it i have tryed reseting the alarm but srill does it but if it is faulty i suppose it wount work. i will have to try and get it on a vag com and see if it throws any hing up. Link to post Share on other sites
