Does anyone know information on replacing the ecu? LOOK ON PAGE 2!
hi guys, does anyone know if it's possible to reset the ecu's adaptations?
The latest from the garage is that because my car was running fine with 6 bent exhaust valves for the past two years, the ecu was compensating by altering the fuel mixture and now i've had the headwork done, it's not bounced back so is running really lean (not running under load at all now). So if the ecu can be reset to learn the adaptations again, the problem may be solved without a new ecu having to be sourced.
Hope someone knows,
Thanks, Katie
PS, I tried to search for answers to this, but i kept getting a message that i'm not authorised to use the search facility, so sorry if this has been asked before (@)<br /><br />Last edited by: katconcarne
Hey kat, search option is offline atm due to the probs it was causing.
Re-setting the ECU can be done by disconnecting the battery! It needs to be off for half an hour, then re-connect it and turn the ignition on to the first click, just so the lights are on. (do not start) Then leave a further half hour. This will re-calibrate the ECU.
If you didnt do the igniton part kat, this may be why it didn't work!
Afaik, sharans are OBD2, so it wouldn't work on your car : (
spoken to the experts and had a vw specialist auto electrician look over absolutely everything and vagcom comes back with no faults, resetting the ecu has made her run slightly better but she's getting worse again, so not apermanent fix. The auto electrician is positive it's the ecu at fault and says i need a replacement. The code off mine is 021 906 258 CH, does anyone know the best place to source a second hand one?
I've found a few with the letters CP at the end, will any other vr6 obd1 ecu do? or does it have to be the CH?
Hope someone knows!
Cheers :)
