matrix 0 Posted January 21, 2007 Report Share Posted January 21, 2007 since rear ending a range rover and having the repairs done it seems different. unless your driving verry slow it doesent want to grip on the o/s under accel and seems unbalanced under braking more lickeley to lock up on the o/s also. from purchase i think it had a slight pull under bracking but now it seems worse, when i told the garage who repaird it they said they couldent find anything bent have also had the 4 wheel alinement done so out of ideas.is it ruined forever or are there checks i can dothx phil Link to post Share on other sites
Russ_vr6 12 Posted January 21, 2007 Report Share Posted January 21, 2007 check the lower wishbones mate,iv known bent anti roll bars causing that too,and check the roll bar links,was the suspension damaged? Link to post Share on other sites
matrix 0 Posted January 22, 2007 Author Report Share Posted January 22, 2007 no suspension damage as im aware, i was lucky where i hit it close to the middle of the bumper where the spare wheel is so a lot of damping, but it crumpled my bonnet up damaged part of the slam panenel and crumpled the fromt part of the wing along with smashing the light all on the o/s. all the internals didnt move but could it have bent the chassis leg. when it went for the mot they found no problems. Link to post Share on other sites
matrix 0 Posted January 25, 2007 Author Report Share Posted January 25, 2007 is it hard to tell if anythings bent. Link to post Share on other sites
