Hi all, anyone got these wheels? I recently recieved a set.. They are 8x17 et32 however they dont clear the front calipers, any ideas? I have seen people running these wheels before. Here is a pic of one fitted to a vr6, I think hes on this forum but im not sure what his username is.
Thanks.
hi mate im having the same problem but with fitting a set of keskin kt5's. yes you can fit spacers but then the outer lip of the wheel sits directly under the lip of the wheel arch and when you go over any type o bump it will slam on the arch and buckle the wing so not a good idea. and as for grinding the caliper surly this is not good practice.
