madmonkee 0 Posted July 6, 2004 Report Share Posted July 6, 2004 i want to put an oil catch tank in connected to the crankcase breather pipe, to remove all liquids from going back into my induction, now do i have to put that temp sensor back in or can i just get rid of all together? What does it do?? Also would it be better if i put a crank breather filter on as well? Will this higher/lower the octane at all?? any helps welcome Link to post Share on other sites
binliner 0 Posted July 6, 2004 Report Share Posted July 6, 2004 there'll probably be somewhere on the catch tank to put a breather... Im not sure what temp senser you mean Link to post Share on other sites
madmonkee 0 Posted July 6, 2004 Author Report Share Posted July 6, 2004 its on the obd1 engines, can i just get rid of it?? Link to post Share on other sites
jcorallo 0 Posted July 6, 2004 Report Share Posted July 6, 2004 its not a temp sensor - its supposed to be a heater - to stop a plug of ice developing in that pipe in winter.BUT I bet if you unplug it and peer into the connector in the 'heater' part you will see thats its a dummy - no parts what-so-ever - it does nothing.Jules[ Edited Tue Jul 06 2004, 11:48PM ] Link to post Share on other sites
madmonkee 0 Posted July 6, 2004 Author Report Share Posted July 6, 2004 why i thought it was a temp gauge..... so if i get rid there will be no probs?? Link to post Share on other sites
jcorallo 0 Posted July 6, 2004 Report Share Posted July 6, 2004 as long as its not doing anything - like I say - make sure its a falsey first....! Link to post Share on other sites
mightyvr6 0 Posted July 6, 2004 Report Share Posted July 6, 2004 I haven't got mine plugged in either, without any problems. Think it was designed like that for the American market.[ Edited Wed Jul 07 2004, 12:15AM ] Link to post Share on other sites
FishWick 21 Posted July 7, 2004 Report Share Posted July 7, 2004 I thought the throttle body being in circuit with the coolant system was supposedto stop fuel icing? But yeah, that sensor is a dummy one! Anyone removed the heater pipes to the throttle body? Notice any difference?The UK doesn't get cold enough for carb icing anymore, just wondering if it will help the 'cold air' cause or not. Link to post Share on other sites
jcorallo 0 Posted July 7, 2004 Report Share Posted July 7, 2004 I thought the throttle body being in circuit with the coolant system was supposedto stop fuel icing? But yeah' date=' that sensor is a dummy one! Anyone removed the heater pipes to the throttle body? Notice any difference?The UK doesn't get cold enough for carb icing anymore, just wondering if it will help the 'cold air' cause or not.[/quote']kev - he's talking about the engine breather pipe....!Also, about throttle body icing - doesnt air get cold as its sped up through the throttle body....?Jules Link to post Share on other sites
binliner 0 Posted July 7, 2004 Report Share Posted July 7, 2004 I thought the throttle body being in circuit with the coolant system was supposedto stop fuel icing? But yeah' date=' that sensor is a dummy one! Anyone removed the heater pipes to the throttle body? Notice any difference?The UK doesn't get cold enough for carb icing anymore, just wondering if it will help the 'cold air' cause or not.[/quote']yeah have heard phatvr6 talk about this... its a simple mod so might be worth trying for the summer anyway Link to post Share on other sites
