Hi there i have just got back from vw with my timing kit i have received 8 things my car is an obd2 VR6 engine code AAA the items were
Guide Piece 021109469
Guide Piece 021109513
Tensioner 021109467
Tensioner 021109509E
Tensioner chain bolt 021109507A
Timing Chain 021109503D
Timing Chain 021109465B
Tensioner chain Bo 021109507B
this is all i got if there is anything else required please let me know as im about to try it out at the weekend and want to make sure i have everything before hand. thanks again
and you will need a rocker gasket aswell....(021 103 483D)
and whilst you are in there i would replace the crank seal (068 198 171) as you need to disturb it to get the lower chain cover off you may as well replace it.....
how come they gave you both upper screw in tensioners??? (they have given you the later chain and later tensioner...)
going back to VW i already have the rocker gasket as its leaking so was going to change anyway so i take it i need something else apart from the oil seal is the upper tensioners right do i need these both. let me know as im going back to collect more parts tommorow and want to change whatever needs changed and order up everything else.
thanks for your help
from your list above :-
these are the same item.. you will only need one of them. there is a choice dependant on engine number .. :-
see pic ..
[lightbox=../../e107_files/public/1170841545_594_FT157827_cam_chains.jpg]1170841545_594_FT157827_cam_chains_.jpg[/lightbox]
circled in red is the choice of tensioners dependant on engine number.
in green is the choice of chains and other tensioner dependant on the same engine number ..from your list you have been priced the later upper chain (no9) and the later tensioner (no13)...??
so what bolt will i take back as they are quite expensive. im going back on monday and have ordered a oil seal mine is a P reg highline engine code AAA let me know thanks and ill take the relevant bolt back and hopefully exchange it for the seal
thanks
J
  • 8 years later...
