madmonkee 0 Posted July 7, 2004 Report Share Posted July 7, 2004 as ive posted before about the wonky wheels, as alot of you know i was suffering from what look like a crabbing car, (drivers wheel sticking out 1/2" more than the passengers, so cant lower it) after having the subframe bolts out and I good ole looking over, we found nothing to be bent or damaged. So we decided to look higher in the suspension setup. There was the answer, the uppermost of the two bolts that join the coil'y to the discs had been pulled over about 1/2". So when i took it in to be mended after i broketed it, all they did was to adjust the bottom camber to pull the wheel out to suit. Nothing is out on the alignment so no tire wear, but shite handling. Now all they gotta do is undo the bolts, push the baby back in and re-align it all up. Monster when you get back have a read, this could be the problem with your front end. Time to slam now [ Edited ][ Edited ] Link to post Share on other sites
28v6r 0 Posted July 7, 2004 Report Share Posted July 7, 2004 ......into the back of another car perhaps??? %-6 %-6 Only Kidding..... Link to post Share on other sites
madmonkee 0 Posted July 7, 2004 Author Report Share Posted July 7, 2004 hope not Link to post Share on other sites
VR6Steve 0 Posted July 7, 2004 Report Share Posted July 7, 2004 Well done on finding your problem. Link to post Share on other sites
