gav_113 0 Posted February 10, 2007 Report Share Posted February 10, 2007 hey all, right today i tried fitting a aux water pump coz mine hasn't got one? the pipes were joined with a socket?? (don't ask) its been this way since i bought the car? the prob i have is firstly water was leaking out of the seal at the bottom of it, and secondly when does it work, has the engine got to get to a certain temperature? because it doesn't work when plugged into the loom? only works when i put a pos and neg to it off the battery..anyone got any ideas?? Link to post Share on other sites
Eat this 2 Posted February 10, 2007 Report Share Posted February 10, 2007 it should run when you turn the engine off i dont know if its supposed to be on when the engines runnning Link to post Share on other sites
gav_113 0 Posted February 10, 2007 Author Report Share Posted February 10, 2007 is it because i didnt run the engine up to temp? also i put sum sealer around gasket so that should stop leak? Link to post Share on other sites
thegoth 5 Posted February 10, 2007 Report Share Posted February 10, 2007 Hi Gav,It should start as soon as you turn the key and the electrics come on, even before you start the engine. It should also run after you remove the key for a long as the cooling fans do.Sorry, but I have no idea why yours wouldn't. Link to post Share on other sites
gav_113 0 Posted February 10, 2007 Author Report Share Posted February 10, 2007 ummmm, focking great!!ill have to trace wires bk, maybe ill check fuses first!cheers m8..if i cant fix it is ok to run engine without one? it has since ive had the car! Link to post Share on other sites
Eat this 2 Posted February 10, 2007 Report Share Posted February 10, 2007 its advisable to fix it as its more of a reliability thing doesnt matter so much in winter but really helps in summer Link to post Share on other sites
SankysVR6 1 Posted February 10, 2007 Report Share Posted February 10, 2007 It should start to run soon as you turn the key to start the engine. And carry on runnig after you switch the car off, regardless if the engine temp is hot or not. Link to post Share on other sites
vr6madmike 0 Posted February 10, 2007 Report Share Posted February 10, 2007 Mines packed up too, well works when it feels like it! Always used to run as soon as you turn the key and for 10mins after regardless of temp. Link to post Share on other sites
guppers 0 Posted February 12, 2007 Report Share Posted February 12, 2007 wierd. i put a new one on mine about 5 months ago because it leaked and sounded rough. comes on when ignition is switched on and goes off when ignition is switched off except if fans are on, then it goes off when the fans go off. i thought this is what was meant to happen to stop hotspots inside the head when the coolant is hot??? :-| Link to post Share on other sites
