charger for low ends , then switch to the turbo ( BIG one :D ) when you have spooled it up :) you'd need to find a way of cutting the charger out of the equation. its not possible to run both at the same time nor would it work to any benifit , say when the turbo eventualy spools up its gonna want to draw twice as much air than what the chargers drawing and it wont be able to drag it past the charger vica versa if its turbo then charger it cant force the air through the charger , and if the charger is still there its going to strangle it , basicaliy become a restriction . youd need to think of soemthign like a bypass valve . but its all entirely possible , and probly be costly .
Twin turbos are better imo.
Less complicated, less parasitic load and less noise.
Drive a 335i or 335d and you'll soon forget compound charging. Both have a MASSIVE torque band.
The Rotrex is small enough and boosty enough to do it probably, the Vortechs; no way. They don't do anything until 3500 rpm, depending on pulley size.
