Geastb 0 Posted July 12, 2004 Report Share Posted July 12, 2004 How easy/hard is it to change the rear disks? I've been told its quite diffficult and my local garage want to charge me £100 to do the job.i would rather do it myself - how long would it take and what tools do i need? Link to post Share on other sites
VR6Pete 1,455 Posted July 12, 2004 Report Share Posted July 12, 2004 you'll need to relace your wheel bearings, as far as i know they are part of disc, and unless they pop out with no problems, you will need to replace them... i got mine replaced at the same time as me discs.. Pete Link to post Share on other sites
Geastb 0 Posted July 12, 2004 Author Report Share Posted July 12, 2004 I've actually got a set of s/h disks that already have the bearings attached....so is it an easy job or best left to a garage? Link to post Share on other sites
acf8181 0 Posted July 12, 2004 Report Share Posted July 12, 2004 can't imagine its that hard really. hard bit may be pressing the bearing in. Link to post Share on other sites
robvr6 0 Posted September 13, 2004 Report Share Posted September 13, 2004 on my mk2 getting the bearing in was the easy part for me, winding that bloody piston back on the calliper was a nightmare and ended up having to get local mobile mech' to fit 'em, beware of the piston !![ Edited Mon Sep 13 2004, 07:57PM ] Link to post Share on other sites
dubloke 4 Posted September 13, 2004 Report Share Posted September 13, 2004 you can get a proper winding tool from halfrauds! you can tap the bearings home with a big socket the same size as the outer race, just dont hit the inner race as it will dislodge and be damaged! apply plenty grease (lm) to the outers before re assembling on the hub! i would be more concerned with using second hand discs more than anything else tbh, especially as they are cheap enuff to buy new! never skimp on brakes! [ Edited Tue Sep 14 2004, 09:18AM ] Link to post Share on other sites
madmonkee 0 Posted September 13, 2004 Report Share Posted September 13, 2004 dont skimp on the brakes dood, respect to the dubloke for pointing this out. Link to post Share on other sites
SankysVR6 1 Posted October 4, 2004 Report Share Posted October 4, 2004 a pair of rear brake disc £42.89,rear pads £16.39 both made by ATE and rear bearings are £10.22 each all including VAT from ECP. Link to post Share on other sites
SankysVR6 1 Posted October 4, 2004 Report Share Posted October 4, 2004 oh yes and don't forget to take the ABS Cog off the old ones. Link to post Share on other sites
Eat this 2 Posted October 4, 2004 Report Share Posted October 4, 2004 if u take the cap off the brake fluid reservoir and the piston should just push open do it slow or ul spill the fluid Link to post Share on other sites
robvr6 0 Posted October 10, 2004 Report Share Posted October 10, 2004 just had mine done, took the garage 3 hours,after taking them an hour to start it, ended up having to cut all 4 calliper bolts 'cos they seized, then they managed to knacker 1 of the abs rings cos they said they had to sweat them off and back on again, which then cos me another 2 hours and £25 to sort out...and they didn't know it had abs before i took it in i'm now looking for a new reliable garage, Link to post Share on other sites
Guest vw mechanic Posted October 21, 2004 Report Share Posted October 21, 2004 raer pad carrier allen bolts can be a bitch to undo and the abs rings sometimes lose there shape so they wont grip the inner hub on the disc definetly worth changing bearings at the same time Link to post Share on other sites
acf8181 0 Posted October 21, 2004 Report Share Posted October 21, 2004 they're not allen bolts on mkIII's are they? Link to post Share on other sites
SankysVR6 1 Posted October 22, 2004 Report Share Posted October 22, 2004 belive me they are. i had hammer and chisel them off on one side. and i coudn't get replacements from VW until the next day.which was bad as i no car for a day Link to post Share on other sites
robvr6 0 Posted October 22, 2004 Report Share Posted October 22, 2004 what difference will having normal bolt instead of original ones ? as when the garage cut mine off the just put normal bolts in, should i replace them?sankysvr6..how much were the calliper bolts from vw ? Link to post Share on other sites
SankysVR6 1 Posted October 22, 2004 Report Share Posted October 22, 2004 there about 30p each, i dont think they will make any difference. it's just that i like to have things like that how they were ment to be. Link to post Share on other sites
Nerih 0 Posted October 22, 2004 Report Share Posted October 22, 2004 going for oem is always a good idea, sometimes its pretty cheap to, and ou can have peace of mind that your calipers arent going to fall off Link to post Share on other sites
