You can convert an OBD1 engine to OBD2 management, but to do this, you need the complete engine loom, throttle body, inlet manifold, ECU, MAF, transponder ring and key from an OBD2 VR. You might be able to get around needing the key & transponder if you get the immobiliser programmed out of the ECU. This is a fairly popular conversion on supercharged VR Corrados.
