ibizaboy 0 Posted April 1, 2007 Report Share Posted April 1, 2007 im really struggling to find out what is wrong with my car.i have a mk2 seat ibiza with a golf vr6 lump in it bored out to a 2.9!the problem i am having is that when i am going either slowish in 1st or 2nd or at a constant speed between 2k and 3k revs in other gears the car seems to lose power but then kicks back in. i can only really describe it as a kind of hiccup!! its as if the fuel is cut off or something and it just stops for a second and then bang it goes again. this can happen with a full tank of fuel, on a staight or around a roundabout and seems to be really random when it happens.in trying to solve this problem i have so far replaced the fuel pump twice! i have also changed the housing for the fuel pump so that it is now in the vr6 housing rather than the ibiza one. i am now clueless as what to do and was wondering if anyone had any experience or ideas about how to solve this problem. bit more info- today i drove the car from the garage wher it is kept 3 miles to my mates house and it did the hiccup thing 5 times, then i drove a futher 25 miles and it only did it twice! i then used it again tonight to do another 10 - 15miles and it did it 3 times thus showing how completely random it seems to be!when i put the engine in i fitted new magnecour leadsnew spark plugsa new air filteramongst other things Link to post Share on other sites
tubby 0 Posted April 1, 2007 Report Share Posted April 1, 2007 Try some carb cleaner dude i had a similar problem and that solved it,you can only try.virgin Link to post Share on other sites
Focker-out 0 Posted April 1, 2007 Report Share Posted April 1, 2007 This could be something as simple as leads, coilpack. dizzy cap or rotor arm but i presume you have changed all this??This problem reminds me of my mate VR6 a few yeras back and after numerous attemps from local specialists, and i say specialists loosely, he took the car to Dubsport who found it out to be the throttle poition sensor was either faulty or needed re setting up, i cant remember which but after that was done the car drove perfectly Link to post Share on other sites
ibizaboy 0 Posted April 2, 2007 Author Report Share Posted April 2, 2007 thankyou ill give the carb cleaner a go and then ask my mate to inspect the throttle position sensor and see waht he can do!!im not a mechanic by any means lol so was just wondering is the throttle sensor easy to locate? Link to post Share on other sites
Focker-out 0 Posted April 2, 2007 Report Share Posted April 2, 2007 Its on the side of the throttle body, assuming that this is an early OBD1 engine?? Link to post Share on other sites
EmkayVR6 0 Posted April 2, 2007 Report Share Posted April 2, 2007 i have a similar problem at the mo, just started last nite but did find no water in the expansion tank, have filled it back up and gone for a run still hesitatin/missfirin, checked water when i got back and still got plenty ingonna have a good check after work 2mos n see if i can find sumthin Link to post Share on other sites
ibizaboy 0 Posted April 3, 2007 Author Report Share Posted April 3, 2007 yes its an ob1 Link to post Share on other sites
