after-market remote locking wiring
Just had mongoose alarm fitted to my 1997 auto VR6. Central locking works OK, but we cannot get it to work remotely off the alarm key pad.
Anyone fitted one before and knows best place to wire the trigger to get the doors to all lock?
Note that the turn the entry key to the left and hold does not send any open windows back to up position, which I believe should happen.
Cheers from New Zealand member..
the trigger has to be wired to the drivers door, if u lock the door manually they all lock, if u do the same on the passenger side only that door will lock. As for the windows up, it should do.... its suposed to be a full closure alarm as standard. Perhaps summit is buggered in the lock? U tried doing it from the passengers side? anyone else???
