VR6Pete's Golf Mk2 VR6 Conversion [Finished]
  • Replies 199
Popular Posts
Ouch with the mk3 mate... Was worrying me when looking into doing Nurburgring the costs of crashing into barriers etc...
sounds as good as I left it last april... if not better! lol
straight on in this picture onto the mk2 hangers... but as you can, see its quite far over to the right side... so carl has chopped off the hangers from the mk3 shell and has welded it on the mk2 shell, as you can see on page 14, it looks alright from the pics, but doest sit 100% central, but looks good enough, and 100x better than the first picture..
couldn't justify spending even more money on a new exhaust, when i was keen to use most things from the mk3 and stuck on the mk2, including indicator stalks, steering wheel, mk3 vr6 shifter, vr6 wide track, mk3 column and steering wheel and even my old petrol tank!
mostly all plug and play really...
Pete
Looking well Pete, glad it all coming together for ya.
A mate of mine has just brought a MK2 16v with the view to convert to a VR6 transplant with MK3 widetrack. He's looking to get a rear end damaged MK3 VR. I mentioned you was just going through exactly this.
Would you be so kind as to list EVERYTHING you took from the MK3 for the conversion?
Cheers mate
that aint air in the tyres ;)
LMAO pete is there anythink you need to get that can't be got from a mk3, Or anythink that gets damaged in the process so it wont go back in my mk3??
Thinking of putting my mk3 in a mk2 untill ive finshed my mk3 shell then swap it all back over
Few more bits have arrived today.. should have them fitted over the weekend.
new HT leads, 2 new samco's and some more heat wrap for my 6 branch.
Cheers Stealth Racing for pulling through and getting me these (apart from samco's) so quickly, and before the weekend.
Happy Days :)
Pete
Ok... Here's a list of stuff I've put on the mk2 from the mk3, including other bits needed to complete my conversion.
From the mk3:
Petrol Tank (optional, just easier to replace it rather than messing about with fuel pumps, i'm lead to believe the 8v has a different pump than the 16v golf - not sure if anyone can confirm this?)
Steering Column
Ignition Barrel / key etc..
Indicator Stalks
Mk3 Steering Wheel
Mk3 Gear Shift Gator
Miltek Exhaust (with mk3 exhaust hangers chopped from my mk3)
6 Branch Manifold
De-cat pipe
Mk3 Brake Servo
mk3 samco's - 2 hoses not used
Mk3 wide track - 5 stud wheel (will require new stretch bolts, front / rear)
Mk3 PAS steering rack
mk3 Eibach Front ARB
Mk3 Koni Coilovers
Mk3 Wheels (needs a slight bit of arch work, nothing a grinder cant sort on the front arches, I need 2 new ones anyway, so will be rolling them properly when I have it re-sprayed)
Mk3 Brake Setup
Subframe / Axle stretch bolts
Mk3 engine loom / fusebox
Mk3 Floor Mats
Other Parts:
Corrado VR6 front cross-member
Corrado / Passat Peddle Box (for hydrolic clutch)
Corrado VR6 twin fans + radiator
Auxiliary Belt - I've now ditched the Air Con compressor
Replaced due to damage etc..
Vibra Technics rear engine mount
Gear Box Case and mount
New Clutch
New HT Leads
Top / Bottom Samco Hoses for Corrado VR6 radiator
Sump needed welding up
exhaust heat wrap
Cant think of anything else at the moment, will add if I remember anything else :)
Pete
