Chiefwiggum29 0 Posted April 14, 2007 Report Share Posted April 14, 2007 Just bought my second golf vr6, had alot of bad luck with my other one. just reading a post about oil temp, and that got me thinking. my oil temp sits around the 100-104 mark. is this ok or should i worry. Link to post Share on other sites
jpturner 0 Posted April 15, 2007 Report Share Posted April 15, 2007 Well I have a 1997 VR6. In normal driving conditions my oil temp is between 96 to 99. If I floor it reaches a 100 to 102. Hope this helps. Link to post Share on other sites
ventovr6essex1 0 Posted April 15, 2007 Report Share Posted April 15, 2007 on the way back from the pod today mine was sitting at about 100 Link to post Share on other sites
Chiefwiggum29 0 Posted April 15, 2007 Author Report Share Posted April 15, 2007 yeah cheers for the help, i musr say that i was giving it some stick when the oil temp was at 100. just can't help but give it some stick, the sound of the engine with the k&n and stuff sounds the bees knees. Link to post Share on other sites
vr6newcomer 1 Posted April 15, 2007 Report Share Posted April 15, 2007 mines got a stage 1 flowed head, temp has been at about 90 to 93, in normal driving recently, but krept up a bit over the last couple of days while sitting in london to about 95, only been upto about 104 when it hit about 135 on a private road last week. Link to post Share on other sites
matth76 1 Posted April 16, 2007 Report Share Posted April 16, 2007 It shouldn't be over 100 if driving normally. It should be 90-98 if driving normally. If it is a hot sunny day and you're doing motorway driving it can creep up to 100 but much more than this is rare. Different types of oil can cause differences in temp. I use Quantum Synta Silver in 10w40 (its the semi synthetic stuff - DONT put fully synthetic in) and now my car uses hardly any oil at all and the temp stays in the 90's all the time. When I used to use other oil I found my car would use up loads of oil. Try changing the oil and see if that gets the temp down.Just make sure the revs are kept below 3000-3500rpm until the engine is fully warmed up to 88-90 deg for at least 10-15mins when driving from cold. This is the same for any performance car. Link to post Share on other sites
Chiefwiggum29 0 Posted April 16, 2007 Author Report Share Posted April 16, 2007 cheers for the help, having a service done on sat. so i'll get the oil changed then. also having pads and discs all round. not cheap Link to post Share on other sites
