Some Turbo parts came last week. PICS..
Well, I was in Bangkok when DHL called med up and told me they had 2 huge packages for me back home in Oslo. So when I got back, my turbo kit has finnaly come.
Its basiclly a Kinetic/C2 stage 3 Turbo kit. Some upgrades have been done to it.
C2/US ECU with custom work from Jefnes.. HOPE IT WILL WORK!
He told me to but on the Bosch 440's, 95mm MAF and try the ECU. Should run fine on idle.
Its a much better turbo that I have upgraded to, for just some extra money.
Im gonna have a C2 8:5-1 headspacer.
Here is the Turbo: Garrett T04 60/1.. AR 70 / 63
Intercooler kit:
3" Downpipe:
Tial 38mm Wastegate:
95mm MAF house from C2Motorsports
[mod edit to resize pics]
Moderator edit by: cadguy
  • Replies 385
Popular Posts
Fitted some stuff today. V-band oil catch tank, Fragola AN6 water lines for the GT35R and the new saturday candy package came from USA today
Went to Oslo motorshow a couple of months ago. Just tought you guys should see this......
Would love see a video of that Club Chairman
More parts
More parts... Bosch 440cc injectors
Garrett again
Bosch Motorsport 044 fuelpump with some more stuff
Racimex oilcooler kit from Germany
Engine mounts and some Powerflex. All ready fitted. Very tight.
My belowed Peloquin that I have had one year with. Back when I had a Z-Engineering charger...
Are you brakes okay with the sand in them?
rest looks great
I had only one choice, and that was to but sand in there, because the fire was pretty big. But no damage was done, and I had a couple off rounds on the track just to cool it all down.
  • 3 weeks later...
Ok, so I got all the parts that I need now. So when finishing work, it was straight down to the garage to check if the new C2 Ecu was working on my Euro car. OBD2.
First we changed the injectors, and was gonna put on the 95mm maf:
Then the problem came... Look at the red signs. Plastic pins. "This is the C2 ECU:
And look at the red signs here. No plastic pins "My OEM Euro ECU"
The plastic pins prevent it from sliding in,
Apart from this, all the pins and everything look exacly the same.
Dremel was the first thing in my mind. But..
No answer from C2 yet... Its been like this since thursday:::::::::::(
Some parts lined before we started:
Front off:
Manifold off:
Head off, ready for cleaning:
C2 Motorsport 8.5:1 headspacer fitted:
Regapping off plugs. 0.024
Putting the turbo togheter:
Turbo kit and exhaust... 3"DP and C2 3" Over axel pice:
Got the head on with new ARP head studs. Looking foreward to some more updates tommorow. Its getting late right now. Two pints, and Im heading for bed.
You can see Bosch 440's here:)
21750 miles old:
The chain was so damn tight, so I needed a solution.... We fitted a BORA VR5 Tensioner. The VR5 tensioner is a little shorter..
Turbo on:
New oilpan fitted
VW techs Corrado VR6 2.9
[img: width=640]http://i169.photobucket.com/albums/u215/Maiden-VR6/MinVR6TurboRunesinCorradoVR6.jpg
Moderator edit by: VR6Rich
Ok, some updates...
The fitting with my Garrett T04S 60/1 Turbo is very tight. So something needs to be done here.
Intercooler mounting:
And the very first start up, with a USA ECU from C2 Motorsports: "Yes it looks like im 16 year all over again:)" I was 16 in 1994:)
Clip 2:
I managed to connect the vacum hoses wrong, so on the forst test drive I had TO much boost. I mean NO traction with a Peloquin i 3rd gear on dry asfalt. Got to 4rd gear, and it was still NO traction at the beggining. Now its some work left to be done. And the car are gonna have 15 psi.
