Some Turbo parts came last week. PICS..
Did you not have your gearbox adapter mount modified to bolt to the end of the casing? I thought I read somewhere that you had welded a piece onto the original UM mount so it was actually bolted with 4 bolts? Been wondering if this is a strong enough setup myself....considered a mount on the chassis leg like the mk4 one but maybe dogbone mount plus adapter mount would be ok...
  • Replies 385
Popular Posts
Fitted some stuff today. V-band oil catch tank, Fragola AN6 water lines for the GT35R and the new saturday candy package came from USA today
Went to Oslo motorshow a couple of months ago. Just tought you guys should see this......
Would love see a video of that Club Chairman
Mistake I did was that the mk3 gearmount was welded a little to low. So both engine and gearbox was hanging a little low on the gearbox side. The 02M mount did not like that... And yes I did weld a extra strength flat steel on the 02M mount.
So in which way should you have raised it then? By means of welding it further to the left of the subframe or by means of a filler piece etween mounting cup and subframe? Just curious as I don't want to Mae same mistake.
Higher up on the subframe.
Mount up engine/gearbox with the 02M mount. Get the engine lined up water straight. Fit the subframe mount perfect and make some welds.
Remove engine/gearbox and weld mount to subframe.
Then, in again with engine/gearbox and ceck that its all 100 % fit.
Small update...
Retorque the arp bolts. 108nm :
Pressured air to clean off the clutch:
Need to make makeself some brackets for the fuelrail:
Brand new VDO pump intank.
Filter for Bosch 044 incl plastic membran so it doesnt collapse:
INA 044 Catchtank:
Then' date=' in again with engine/gearbox and ceck that its all 100 % fit.
Thanks, that's exactly what I did do so hopefully it will be fine.
  • 1 month later...
Very strong silicone that support the metal sement that I have put in the two oil channels. Looks ass, but it works very good:
Not my car, but got a set off ABT sideskirts in the mail today. The oem skirts are shit, and Ive been driving around last 2 years with 1.5 sideskirt :)
Federal RSR street slics 215/40-17". They are in the same league as R888s, but alot cheaper. At least here in Norway, wich is the worlds most expensive country.
UM oilcooler bolt. Do I miss something here? The end cap is not even close to fit.........
  • 5 weeks later...
very nice
Thanx Jim.
Some updates.... Soon to be ready. Feels like things take forever to be finished with. Do all the work alone' date=' and im not a car mechnic in any way. Just think its fun to see progress, and be happy with the result.
Here some pics: ;)
AN6 in/out from IE tank fuelrail. AN6 fitted perfect inside the frame/chassi where the stock lines was sitting..
[img']http://i169.photobucket.com/albums/u215/Maiden-VR6/IMG613.jpg
UM billett oilcap and UM external oilcooler tube. So I can run oem oilcooler and the Mocal 16 row.
02M Dogbone with Powerflex bushing.. Shortend a little bit. Tight like a tiger :)
Waiting for my intercooling pipes to be welded. Did weld them my self, but I gave up. They failed my water leak test several times. So a friend is gonna do it for me.
I wish I had have done that dogbone mount before I gt subframe powder coated Doh! Might still do that' date=' makes sense...
Nice work Kristian. Any videos of your 800whp friend yet?! :D
Thanx.
Here are the build thred http://www.vr6.nu/phpbb/viewtopic.php?f=27&t=8489&start=465
It used to have twin Garrett GT3071R turbos. Did 643whp with that. Took them off and fitted a Precision 6766 T4 and made 794whp. The distibutor wasnt doing that well over 2.4 bar off boost. It will be fixed, and 800+ whp is easy to achive. E85 offcourse :)
  • 1 month later...
Ive been driving all summer from 15-28 psi. No issues. Adjusteable fpr and AFR is spot on @ 11.6 - 12.0
Matt at Unitedmotorsports fixed my Mocal oilcooler issue. Got their Oil cooler bolt and end cap. The Ebay Mocal 16 row fitted nice.
Some random pics.......
