2.9 bottom end onto a 2.8 top????
as titled,
I think my piston rings have failed so it would be a cheaper option just to change the bottom end. can I fit a 2.9 bottom end onto a AAA 2.8 engine?
OR:
if I replace it all with a 2.9 lump will the loom need changeing to?
OR:
if its not the rings and just leaking valve stem seals can I run a 2.9 top end(is there a difference) with AAA inlet on a 2.8 bottom end??
depending on what my problem is, eather way its a good oppertunity to upgrade a bit, but money is tight!!....any thoughts??
thanks in advance if you can help
Pete
Yep you can run a 2.9 bottom end with your 2.8 head both engines are exactly the same, its the electronics that differ between obd1 and obd2 some early engines have a dist changeover was about mid 93.
The cheapest option would be find a good motor in a scrappys so you dont need to go changing timing chains gaskets etc providing you find a good motor :)
