cabrioman 6 Posted April 28, 2007 Report Share Posted April 28, 2007 this has prob been asked b4 but wot kinda bhp can i run b4 i need to play around withthe internals of the beast???been lookin at turbo kits and hope fully goin for a stage two kit in the winter / new year tony Link to post Share on other sites
Eat this 2 Posted April 28, 2007 Report Share Posted April 28, 2007 ibivr will be more clued up but i was under the impression 500 bhp was fine with a thicker head gasket to lower the compressionmines running 320 bhp on stock compression and its absolutely fine internally so far Link to post Share on other sites
cabrioman 6 Posted April 28, 2007 Author Report Share Posted April 28, 2007 oh rite thats cool then so wot kinda system u runnin turbo or charger??? Link to post Share on other sites
Eat this 2 Posted April 28, 2007 Report Share Posted April 28, 2007 12 psi vortech supercharger no intercooler stock everything Link to post Share on other sites
6potmkII 0 Posted April 28, 2007 Report Share Posted April 28, 2007 it might make 500bhp, but how long will it last at that, thats the Q? i would say reliablyish 350hp on stock internals. it depends on what route of tuning you take and how much power you want mate, if you want for example 400bhp and a RELIABLE engine, u need to build an engine thats good for say 550bhp. Link to post Share on other sites
IbiVR 0 Posted April 28, 2007 Report Share Posted April 28, 2007 Stock engine is quite strong. For a turbo i wouldnt run more than 6psi into a totally stock engine, should get you 270ish bhp. Drop compression a notch or 2 with a spacer and you can run about 15-17 psi, that'll give you about 400bhp.Anymore than that and you need to stick in uprated arp bolts. Use arp main studs and head studs, and use arp rod bolts in the stock rods, and you should be good for 25 ish psi - 550odd bhp, but your are approaching the limit and really as above if your building a 550bhp engine you should really be looking at custom pistons rods.Go for middle ground, drop cr, arp everything, and run up to 20 psi in it and you'll have a good realiable 400bhp engine.Tom. Link to post Share on other sites
cabrioman 6 Posted April 29, 2007 Author Report Share Posted April 29, 2007 400 bhp spudns good to me as im need to take the head off any way to sort out the valve steam seals so as im there i mite as well put the thicked head gasket oand stronger bolts in , wot sot of cams should i run with a turbo or wil starndard be ok ???will i need ot put double valve springs in as well ??? Link to post Share on other sites
IbiVR 0 Posted April 29, 2007 Report Share Posted April 29, 2007 I'd stick with the std cams, they are fine for turbo, and no need to uprate valve springs unless your planning big revs.Tom. Link to post Share on other sites
cabrioman 6 Posted April 29, 2007 Author Report Share Posted April 29, 2007 where abouts can u get all arp stuff from is there a recomended supplier or just hunt around for the cheapest ??? Link to post Share on other sites
IbiVR 0 Posted April 29, 2007 Report Share Posted April 29, 2007 Hunt around, you can usually find them on US ebay quite cheaply. Bear in mind you'll probably end up paying vat and duty on stuff bought from the US though.Tom. Link to post Share on other sites
cabrioman 6 Posted April 29, 2007 Author Report Share Posted April 29, 2007 oh rite well im not plannin on doin it till the winter and new year so got a while to save and hunt around for it all thanks for all the help thou tom Link to post Share on other sites
