Bleeding the Coolant System
HI there i was wondernig if anyone could help me regarding bleeding the coolant system. my golf currenty has an air lock in the system after changing a heater matrix and have heard slight bubling at times and noticed that fan is on more than i would expect. can anyone tell me how to do this as i want to get it solved quickly so i dont do any head gaskets in or anything like that. your help is appreciated
ran the engine with the heaters on red hot adn just let it idle of give it some low revs to get the water flowing as far as i know there aint a bleed screw or anyhting, also take it on a drive but keep a botle of coolant in the car cos the level will drop after drivin .... good luck matey
  • 2 years later...
Got the same problem, tried bleeding it and more air seems to keep coming out. A little bit of steam came up from by the rad, but i'm not losing water. Also was told that once it's up to temp with the cap off to give it some revs to get the air moving round the system but all that did was make the coolant over flow. all I can hear in the car once i've turned the engine off is water rushing round the heater matrix. Any idea's cuz this is drivin me mad.
