engine running hot fans always on
HI there this is an add on to a previous post as i was having problems with the coolant system and found that the fans were coming on a lot and that there was slight bubbling sometimes when i switched the car off. does anyone have any ideas if it could be something else the engine temp never seems to go over 90 either.
thanks again
what do you mean just the pump working its sounds just bubling dont know what would cause the fans to come on so much plus they seem to only go one speed as well i have not long chained the temp sensor on the cars as this got the fans working. thanks for your help
