Just Been Having A Look
and came across these, Autotech Sport 262° 12V VR6 Camshaft Set
there $299.99 or there is some Schrick 260° for £699.95
anyone know which would be best and provide best power considering i not very rich.
cheers peeps !
Shrick or Eurospec are very good... "Cat" 262 cams are also supposed to be very good according to the vwvortex forum. All these makes of cam provide a good even power increase throughout the rev range, as opposed to just shifting power higher up the rev range and making you lose some low down torque which a lot of cheaper makes do. I would get Shrick if you can afford them or Eurospec. I believe stealth supply both at quite a good rate. Not heard of the autotech ones you mention though
