CanadianVR6 0 Posted May 22, 2007 Report Share Posted May 22, 2007 Hey guys, after opting for coilovers over a spring and dampner kit, im hearing a creaking noise when steering at low speeds. Ive just installed the coilovers last weekend, and didnt notice the noise till a couple days after?? Anyone else experienced this? Link to post Share on other sites
cabrioman 6 Posted May 22, 2007 Report Share Posted May 22, 2007 did u change the top mounts when u fited the coilover set ??? Link to post Share on other sites
Seademon 0 Posted May 22, 2007 Report Share Posted May 22, 2007 Could be bushes of some sort? Link to post Share on other sites
CanadianVR6 0 Posted May 23, 2007 Author Report Share Posted May 23, 2007 Ya, changed top mounts and bearings...It sounds as if the springs ar turning on the dampner or somthing, if that makes any sense......When installing the the new top mounts they were fitted directly on top of the top cap on the coilover is this correct? Wasnt sure if there should be somthing between the two as the fit didnt seem perfect? Link to post Share on other sites
Mk1dubzter 0 Posted May 23, 2007 Report Share Posted May 23, 2007 most coilovers have a nut on the spring capwhich your top bearing will rotate on..is there a nut fitted there ??? Link to post Share on other sites
CanadianVR6 0 Posted May 23, 2007 Author Report Share Posted May 23, 2007 ya there is, so im assuming ive got it assembled correctly then. Link to post Share on other sites
CanadianVR6 0 Posted May 23, 2007 Author Report Share Posted May 23, 2007 Actually, let me rephrase that the bearing is sitting directly on the spring cap, and theres a nut holding the bearing on..it looked like there was a race machined on the dampner shaft for a bearing, Link to post Share on other sites
