Engine Trouble Code 00533 (AAA VR6)
Hey Guys (and girls :P)
Anyone know what 00533 - "Idling Speed Regulator Present Adaption Limit Not Reached" means!!!!! Cannot see anything on the web that relates to that bit. I am guessing a sensor or air leak? Everything seems fine bar the idle is way high (800-900rpm) and that makes first and reverse a right pain to crash into.
Nothing else showed up on a code scan bar that but the guy with the reader does not know VW's at all but at least we got a code from it.
Regards,
Steve
Hi Pete, (?)
08/1995 - I have the square side repeaters but a 16 pin diag connector - so not 100% sure - what's the correct way to prove the right version?
OBD1 - found the FAQ with a decent picture of the TPS and that hose from the air intake!
Regards,
Steve
