SteveWalker 0 Posted May 23, 2007 Report Share Posted May 23, 2007 Hey Guys (and girls )Anyone know what 00533 - "Idling Speed Regulator Present Adaption Limit Not Reached" means!!!!! Cannot see anything on the web that relates to that bit. I am guessing a sensor or air leak? Everything seems fine bar the idle is way high (800-900rpm) and that makes first and reverse a right pain to crash into.Nothing else showed up on a code scan bar that but the guy with the reader does not know VW's at all but at least we got a code from it.Regards,Steve Link to post Share on other sites
VR6Pete 1,455 Posted May 23, 2007 Report Share Posted May 23, 2007 What year is your VR? OBD1 or 2? Link to post Share on other sites
SteveWalker 0 Posted May 23, 2007 Author Report Share Posted May 23, 2007 Hi Pete, (?)08/1995 - I have the square side repeaters but a 16 pin diag connector - so not 100% sure - what's the correct way to prove the right version? OBD1 - found the FAQ with a decent picture of the TPS and that hose from the air intake! Regards,Steve Link to post Share on other sites
