steveg60cab 0 Posted May 24, 2007 Report Share Posted May 24, 2007 i've had a few probs with my obd2 vr, had a diagnostic check to reveal it needed a new air mass meter and inlet temp sensor and it had an idling issue. i changed the AMM and ITS, but it still idled at 400rpm...if i was lucky!! anyway i'm letting you all know that i had the fault codes erased from the diagnostics and my idle returned to normal, so if you're suffering like i did for weeks, try that Link to post Share on other sites
adam_christie 0 Posted May 24, 2007 Report Share Posted May 24, 2007 What's normal idle? Link to post Share on other sites
vr6madmike 0 Posted May 24, 2007 Report Share Posted May 24, 2007 If you replace those parts you should clear the codes anway, so if you hadnt replaced those parts and just cleard the codes the problem would have came back. Link to post Share on other sites
steveg60cab 0 Posted May 25, 2007 Author Report Share Posted May 25, 2007 easy to change the parts, but no laptop = no code wipe! normal idle is 800rpm ish Link to post Share on other sites
VR6Rich 3 Posted May 25, 2007 Report Share Posted May 25, 2007 Yeah its normal to idle at around 750rpm.Glad you got your problem sorted Steve :-) Link to post Share on other sites
Jk* 0 Posted May 30, 2007 Report Share Posted May 30, 2007 Mine idles around 600-800rpm. Link to post Share on other sites
adam_christie 0 Posted May 31, 2007 Report Share Posted May 31, 2007 Boo! Mine's at 500........so I've got a problem or what? Link to post Share on other sites
spanky 0 Posted June 1, 2007 Report Share Posted June 1, 2007 Mine idles (when warm) at dead on 650rpm Link to post Share on other sites
