Anna_golf 1 Posted June 2, 2007 Report Share Posted June 2, 2007 how do i do it without snapping things off, i cant seem to find any srews holding it on Link to post Share on other sites
thegoth 5 Posted June 2, 2007 Report Share Posted June 2, 2007 IIRC part of the grab handle comes off to reveal some screws. What are you taking it off for? Link to post Share on other sites
Focker-out 0 Posted June 3, 2007 Report Share Posted June 3, 2007 Pop off the door handle cover, two screws inside there, and remove the door pin, the door card should then just unclip. Link to post Share on other sites
Anna_golf 1 Posted June 4, 2007 Author Report Share Posted June 4, 2007 got it off! woop woophad to get it off to change the electric window motor. Bit of a bitch to get the actual motor out tho Link to post Share on other sites
Focker-out 0 Posted June 6, 2007 Report Share Posted June 6, 2007 Unfortunately a common problem :-( Link to post Share on other sites
c4mbl 1 Posted June 7, 2007 Report Share Posted June 7, 2007 got it off! woop woophad to get it off to change the electric window motor. Bit of a bitch to get the actual motor out tho Any tips Anna?? I need to take both mine off as both my motors are knackered, but have headr that its a total pain? Do you need to buy new sound proofing if you need to tear the original/existing stuff??Thanks alot!! Link to post Share on other sites
ben_notts 0 Posted September 15, 2007 Report Share Posted September 15, 2007 how do you pop the front off the door grip without chewing the edge of the grips off? im scared that if i push a screwdriver up itll kink the plastic grip! Link to post Share on other sites
