flashing oil warning light and dead rev counter
loose connection / cracked solder on dials? my rev counter went, so i took the whole look out, but found nothing wrong so took it to LUCAS and their electrician found a hairline crack on the solder, so small he found it with a magnifying glass
Ok so Ive just completed an oil and filter change and I still have a flashing oil warning light :-(
Next step is to get the oil pressure tested. Is it a straightforward job to change the oil pump? Or does it involve extensive dismantling?
Am I best to let the garage do it or tackle it myself?
Thanks for the replies so far ;)
Ok so so far I have done the following:
Oil and filter change (nothing)
Oil pressure test (nothing) pressure is spot on.
Replaced hi and low pressure switches (nothing)
I still have a flashing oil lamp and a dead rev counter. :-(
Any ideas (m)
Ive even tried things like bridging the bonnet switch, as apparently this can sometimes set of the lamp.
  • 5 years later...
